โMar-26-2016 09:53 PM
โMar-30-2016 08:00 AM
โMar-29-2016 10:00 AM
โMar-28-2016 09:11 PM
rjf7g wrote:
My 1992 Tioga had a lot of leaks - the whole back wall was basically rotted out and there were issues in the bunk area as well.
โMar-28-2016 09:09 PM
j-d wrote:
Pressure testing for leaks in an RV is done professionally with a SealTech machine like this The section between the two silver bands is a collapsible tube and the square top clamps to a roof vent.
It takes a high volume low pressure air source. You don't want to blow the RV apart at the seams, but it also leaks lots of air out of places that aren't water intrusion sites. RV is pressurized then the person doing the test sprays soapy water on all the RV's seams, penetrations, etc. Bubbles are a leak source.
DIY approaches use leaf blowers, job site ventilators, furnace blowers, etc. Design should include a manometer to verify pressure is adequate but not excessive. I want to build my own tester.
FYI - Residential Heat/Vent/Aircon (HVAC) shops have a "Blower Door" that contains a fan and expands to fit, well, a residential door, and do a pressure test on a house. It can be used in an RV if adapted to the curved door frame of most RV's so if you know somebody in that business they might be able to help you.
โMar-28-2016 09:08 PM
Bordercollie wrote:
You might consider buying a used "portable" generator but it will need to have 4000 watt capacity to run your roof AC unit and microwave oven at the same time. It could be mounted on the rear bumper on some kind of a sliding mount so you would have access to the rear cargo bay door. My advice, save your money and buy a newer rig with standard RV generator that starts easily and works properly to run the roof AC, etc. BTW, people who camp "off the grid" often go with expensive solar power and large banks of batteries and high capacity inverters. Running an RV generator a lot is an irritant problem when camped near other campers.
โMar-28-2016 08:38 AM
โMar-27-2016 07:44 PM
โMar-27-2016 07:18 PM
Bordercollie wrote:
You seem to have realistic expectations. Have the engine cooling system, brakes, including front flex lines and fluid change , compression, transmission and steering/suspension checked and get estimates on replacements/repairs needed to make a decision to buy or not. Make sure that RV generator and converter charger, fridge and dash and roof AC are working properly and no water leak damage. Check awning fabric. If tires are over 4 years old by imprinted date codes, they'll need to be replaced for the safety of your rig and your safety.
An old rig can cost $10K+ in repairs the first year to get it fully usable for touring and camping not to mention delays/problems on the road.
โMar-27-2016 06:40 PM
ksg5000 wrote:
You can always have a mechanic look at the rig. Are you sure about the towing as I doubt an older 30 ft Class C would have much towing capacity - they come out of the RV factory pretty much maxed out on weight (at least mine did). If you do go forward spend an addition $100 or so and get the rig pressure tested - should identify potential roof/window leaks - something you should consider on any used rig.
โMar-27-2016 05:13 PM
โMar-27-2016 08:28 AM
โMar-27-2016 07:05 AM
โMar-27-2016 03:56 AM
