Charlanae
Mar 20, 2019Explorer
1996 HR Endeavor LE slide-out height adjustment
Our living room/kitchen slide is low on the rear so that it doesn't contact the outboard seal or wiper at the top and is rubbing the lower seal hard. This leaves a gap where the slide meets the side wall of the coach and where water can run in on top of the slide. In the compartment below there is a large roller wheel with "spikes" on it that mesh with holes in the square tubing that rides on it to slide it in/out. This powers the slide in/out like a rack and pinion. It is enclosed above it with thin plywood that is the ceiling of the compartment. There must be an adjustment there to raise the slide but I can't find access to it. The cabinet bottoms are carpeted and looks original with the framework sitting on it. Does anyone know how to access the adjustment? Surely there was some allocation made for it but I am not finding it. I have spoken with the current HR Tech support but this was built by the original Monaco Company before closing and they have no info on it. Thanks for any help!
