navegator
Mar 12, 2015Explorer
There are two places where you will find fuses, one is under the dash left corner and the other one is in the engine compartment also on the left side, on the cover of both there should be a list of what fuse goes to what and the relays on the one in the engine compartment.
The fuse box in the cabin also has the turn signal relay, I suggest that you replace it with a heavy duty electronic one, the cheap ones supplied are not strong enough to power all the lamps of the combined turn signals.
navegator
navegator
38,766 PostsLatest Activity: Jan 10, 2026
