bullydogs1
Jan 15, 2018Explorer
The system 12v heater in the wet bay is controlled by a "snap disc" this disc can be mounted anywhere in the wet bay..when the disc itself gets near 35 degrees it will snap the heater on and go off when it is 45 degrees..If you can find the snap disc, I'd spray a duster spray on it (it's cold) and it will turn on the bay heater for a test..These things have been known to fail and you don't want it to fail when you need it..After the test, it goes off within 5 minutes...My snap disc was mounted on the upper right of the wet bay behind some kind of panel..Make sure the system heat switch is on..and DO NOT DRY CAMP with this heater on...if you do and it goes on the batteries will drain very quickly..so if you feel it is getting cold and you need it..shore power or generator.
