donfrump
Dec 29, 2015Explorer
willald wrote:donfrump wrote:pianotuna wrote:
Is the part necessary?
most states require annual emmission testing on vehicles
..But not on a vehicle built on a truck chassis like this, with a GVWR well over 10,000 lbs.
Not that I'm condoning not replacing the catalytic converter, just pointing out that from a legality standpoint, original poster may well not have anything to worry about.
Will
every state is different and every county in each state lots of states require emission tests on gas motor homes from what I have read and been told?
FOR EXAMPLE::
If U live in Colorado and in a County that requires the emmissions testing. Whether you own a gas or diesel you are required to get a full emmissions test on your rv before you are allowed to purchase or renew your lic. plates.
NOW that being said if hes exempt in ohio as u say. There is no way I would install the converter. Better power without one and sounds better(lol)
38,705 PostsLatest Activity: Jan 20, 2025
