proaspen's avatar
proaspen
2006 Fleetwood Bounder 35E (Gas)
Had the utility light on the other night, as well as the light in the utility compartment. When I was finished, I turned the compartment light off, and everything went dark, including the external utility light. I think I burned a fuse. Now I'm looking for the fuse panel. I think it is in the one to the left of the driver's seat. I popped off the panel and there are fuses there. However, no diagram. Anyone know which one controls the untility light? Or, do I have to do it the hard way and pull each fuse? Appreciate your assistance. PROASPEN
  • Thanks! Turns out the fuse is in the battery control box located outside the rig in the same compartment as the propane tank. Fuse # F21
  • Check the fuse panel in the bedroom. It is where the 110 V AC breakers are located but there is also a fuse panel for 12 V DC things in the same cabinet, might be location for what you are looking for
