Westenthal's avatar
Westenthal
2013 Newmar Mountain Aire water leak
I have a 2013 MADP model 4319 with raised rails around the roof. I have been fighting a leak that I thought was coming in around the top window by the drivers seat. I have put silicone caulk anywhere there could be a problem area and it still leaks. The last few days there isn't any water coming down around windows but there is still water coming in around interior of windows. I now think the water is coming from snow melt around the raised rail gutter system. Maybe the drain hose has come off or has crack. Has anyone else experienced an issue like this?
  • this is what we had done
    we went to a place in Georgia and it worked great to locate a leak that ultimately was coming from the over the front door awning that hadn't been sealed properly when it was mounted.
    Or you could just throw sandbags on the roof. :B.
    Get it leak tested or you'll go nuts trying to find it.....Dennis
  • https://rvleaks.com/
    sealtech takes the guess work out.well worth the time and money
