David_krystof's avatar
Dec 31, 2016
76 Dodge Sportsman Class C, Brake Issues, wont hold pressure
I have a 1976 Dodge Sportsman Class C Motor home. I have replaced ALL NEW the master cylinder, power booster, front calipers, rear wheel cylinders, pads and shoes. I have bench bleed the master cylinder, bleed the brake lines and also reversed bleed. It took all the fluid it needed to fill up the master cylinder from the wheels but still can't keep pressure on the break. It pumps up but won't hold the pressure.
