Sam_Spade
Oct 28, 2016Explorer
Sneeblii wrote:
It only hisses after being hooked up for a good period of time
Sneeblii wrote:
Red to pos black to neg. I tested reads fully charged battery
What exactly did you test that made you believe that it was fully charged ?
And what did the voltage read WHILE it was hissing ??
I mean no offense here but the wording of your posts on this subject so far indicates a lack of a good basic understanding about battery and charger systems.
I suggest that you look for the link, which has been posted a hundred times, to the basic tutorial for 12 V systems use and care. I'm sorry but I forget the name; maybe someone will post it for you again.
Failing that, you should take it to an RV repair shop and ask them to do a couple of quick tests and diagnose whether or not there is a problem......and explain to you how the 12 V system works on THAT model.
P.S. Having this same discussion in more than one thread is just confusing to everybody. You should pick ONE and stick with it.
38,707 PostsLatest Activity: Feb 18, 2025
