bsinmich
Aug 11, 2013Explorer
It should be on the suction line, coming from the evaporator. The pressure side is the line going to the condensor.
Evaporator is the part inside that gets cold and condensor is the part in front of the radiator that gets rid of the heat.
We had a Jamobree Rallye 27Y, with the rear bunks and put a few miles on it before selling it to a friend.
She is still a friend also. The reason for the two ports is so you can connect a manifold gauge set to compare pressures on the lines.
38,705 PostsLatest Activity: Jan 21, 2025
