malojeer's avatar
malojeer
99 Allegro DP
We are looking at a 1999 Allegro 37 DP with 1 slide. It has the
Cummins Allison combo and only 30,000 miles. The coach is in excellent condition. Paying 25,000. Any info positive or negative would be appreciated. We are going from a 5th wheel to a class A because I want less work involved when going camping.
  • Sounds like you made a good choice. Sometimes I try to bite off more than I can too!
  • Thanks for the replies but we decided to pass on the coach. After purchasing I realized that I couldn't afford to repair if something major broke. I think we will hold off for awhile. I am thinking of about a 22 or 23 ft class c.
  • Did you check the tire codes? Big expense if they need replacement. $3200-$5000 bucks. Refrigerator recalls done? Maintenance records? Did you check for any major leaks?
  • You might want to check on the Tiffin network (tiffinrvnetwork.com) as well for help with your question.
  • Which Cummins and which Allison?
    Cummins B or C-- what HP?
    Allison 2000 or 3000 series?
