- tropical36Explorer
Mrsmoos wrote:
Thank you all so much--SO very helpful! We were thinking we would have to spend at least $300 for a camera set up!
If ordering one now and with my inside the rear closet mounting, I'd go for this one...
REAR CAMERA SYSTEM
, as the camera I got was for a license plate. No problem though and just made up an alum. bracket for it. - MrsmoosExplorerThank you all so much--SO very helpful! We were thinking we would have to spend at least $300 for a camera set up!
- JagtechExplorerI also bought and installed an inexpensive 7" monitor / camera system, from eBay. It works well, but needed some "shimming" on installation, as the camera view was off to one side by a bit. Its been nice and bright / clear, and is active all the time the ignition is on.
Less than $100. - JoeTampaExplorerI bought this one and love it. 2 camera wired color system for $135!
Esky 7-Inch TFT LCD Color Monitor Car Backup Rear View Camera System (Night Vision, Side Camera)
https://www.amazon.com/dp/B007OOU77G/ref=cm_sw_r_cp_tai_IqdBxbKDCNEBZ - tropical36Explorer
Mrsmoos wrote:
Holy smokes Tropical--that is very reasonable. Do you think they would mount on our older (1992 Southwind) Motorhome using the existing wiring from the original?
Also Dale could you link to what you bought? And is there a size of monitor we want to stay under?
How many cameras can you put on one screen/ receiver?
I reviewed my order for linking it and it said that this particular model was no longer available and meant to include this link for another choice of which there are many... Back up Cameras
I have no idea about your existing wiring, without getting into it and on mine, even had thoughts of coming in from the rear bottom side with power, if needed. Turns out nothing else was needed and most likely, your's will work out, also.
Either way, you can run it, wireless and did test that out, as well.
I believe I can use two of something with mine, but don't remember if it's cameras or monitors...lol - MrsmoosExplorerHoly smokes Tropical--that is very reasonable. Do you think they would mount on our older (1992 Southwind) Motorhome using the existing wiring from the original?
How many cameras can you put on one screen/ receiver? - tropical36Explorer
Dale.Traveling wrote:
The Voyager systems are nice but my RV budget wouldn't support. Replaced the single camera CRT based monitor and associated B/W camera with a color system I got from Amazon for less that $100.
Here's the one I got from Amazon and installed. Looks and works great. Didn't use the wireless, as I was able to use the existing wiring.
They don't have this particular one at present, but many more like units...
Esky High Definition Color Wide Viewing Angle Universal Waterproof Car Rear View License Plate Backup Camera with 7 Infrared Night Vision LEDs
Sold by: Hisgadget Inc
$17.99
Submit
Buy it Again
Leegoal 7" TFT LCD Color 2 Video Input Car RearView Headrest Monitor DVD VCR Monitor With Remote and Stand & Support Rotating The Screen
Sold by: Also Popular
$24.45
Submit
Buy it Again
BW® 2.4G Wireless Color Video Transmitter and Receiver for The Vehicle Backup Camera/Front Car Camera
Sold by: BestSupplier
$10.24
Submit
Buy it Again - Dale_TravelingExplorer IIThe Voyager systems are nice but my RV budget wouldn't support. Replaced the single camera CRT based monitor and associated B/W camera with a color system I got from Amazon for less that $100.
- fcooperExplorerSomething to consider:
My factory installed camera (non adjustable) gave me a good view of the front of the tow car, but not much info about surrounding traffic. When the camera/monitor died, I installed two wired cameras on the rear of the motorhome so that I could have a close up view or a longer range view. This flexibility can also be accomplished by a single camera with the tilt and pan feature, which is more expensive. I use both cameras a lot: The close up one for positioning the motorhome for connecting the tow car or for backing up and the longer range one for viewing the traffic.
The vendors mentioned above have good reputations. There are a lot of inexpensive systems available on Amazon and Ebay. I've had good luck with the cheaper 7 inch LCD Color Monitors from Ebay. It's easy to go too cheap on the camera however.
Fred - rgatijnet1Explorer IIII added the Voyager with the side view cameras and am very pleased with the results. Going on 5 years now with no complaints. It is a wired camera but with adapters I was able to use the old cables from my Jensen B&W camera set up.
I also like that I can adjust the camera to view straight down to well over my toad with just the push of a button on the monitor. It also has the outside audio so can hear directions from someone standing behind my coach.
About Motorhome Group
38,707 PostsLatest Activity: Feb 28, 2025
