valhalla360
Mar 02, 2020Navigator
PastorCharlie wrote:
A second battery is good and four batteries are a double plus. It is best if they all be the same and same age but if not they will still work but may not be as proficient.
The problem if the batteries are in different condition is one will tend to hold a higher voltage resulting in the 2nd constantly drawing juice...this will wear out the better battery...hence why you don't want to add a nice new battery to supplement and old worn out battery...your nice new battery will quickly achieve the same condition as the old worn out battery.
Also, make sure you can keep them close by and use good quality connections to avoid losses in the connections.
38,705 PostsLatest Activity: Jan 23, 2012
