Hi,
If you are having low voltage, first thing is to switch the refrigerator to gas only - if possible. It will lower the amp draw on the RV, and thus less voltage drop across the cord, ect.
Check the power plug to shore power. If it is hot, then the campground power plug might be bad, with the brass connects inside not clamping well to the RV plugs, causing them to overheat and then the brass to weaken further.
Many campgrounds with 30 amp circuits only are typically wired with #10 wire, and it can have a larger voltage drop than a 50 amp campground. Most 50 amp campgrounds put several RV posts on one 150 amp circuit breaker fed with #1 wire. THis wire is so thick, that typically there is very low voltage drop to the RV sites, even when they are more than 100' from the transformer.
You can buy a Hughes Autoformer or other voltage booster. It will take in 105 volts and put out about 115 volts, so that the A/C units will be happy again!
Fred.
Porsche or Country Coach!
Kangen.com Alkaline waterEscapees.com
