Jul-31-2014 08:11 PM
Aug-01-2014 04:22 PM
Aug-01-2014 02:07 PM
Aug-01-2014 01:59 PM
Aug-01-2014 01:33 PM
VintageRacer wrote:
The air governor controls the cut-in and cut-out pressures for the air compressor. It reads the pressure in the system and typically cuts in at 95 psi and cuts out at 120 psi. That 25 psi difference is not adjustable as it is set by the internal spring, however the range is adjustable - you can have 90 psi - 115, or 100 psi to 125, for example. The air dryer purges every time the compressor reaches the governors cut-out pressure point. When it purges, all of the air inside the air dryer and the line from the compressor to the air dryer is exhausted out to atmosphere, and the purge valve is left open until told to close when the system pressure reaches the governor's cut in pressure. So purge cycles are completely dependent on air pressure in the air system. If you have a rapid purge interval, or if the air dryer is purging out of sync with the rise and fall of air pressure in the system, then suspect a governor issue, although to be honest they are extremely reliable. If the governor seems to be operating normally as far as air pressure control is concerned, then the purge valve could be failing.
The normal test is, with engine running at 1,000 rpm, fan the brakes and observe the pressure falling with each press, until you reach 80 psi on the gauges. Observe the pressure begin to rise (governor cut in) then time the rise from 85 psi to 100 psi. This time should be around 30 seconds or less and is called the compressor recovery time). Then watch the pressure rise to 120 psi or so, and the governor reaches cut-out pressure and the air dryer should purge. That is the only time the air dryer should purge, after a compression cycle reaching cut out pressure.
Brian
Aug-01-2014 09:53 AM
Aug-01-2014 07:46 AM
Aug-01-2014 07:18 AM
Aug-01-2014 03:58 AM
Jul-31-2014 10:52 PM
Jul-31-2014 10:46 PM
Jul-31-2014 09:52 PM
