fuzzyface's avatar
fuzzyface
Aqua Hot panel dead
Member
michaelpatri's Avatar
I lost power to the coach, and the house batteries died. I managed to start the genny, and am charging the batteries with it. The problem I can't seem to resolve is that there is no power to the aqua hot control panel which also has the water pump and bedroom slide switches on it. The water pump will work from the other switches, but this panel seems dead. Any suggestions on where to start looking for solutions??
  • fuzzyface wrote:
    Member
    Running the gen will not charge the battery back up unless you run them 6 hours plus. Put it on a regular charger.
  • FIXED....Shortly after posing this question, I went to the MH and shut off the house batteries....salesman switch. Turned the batteries back on and voila....Aqua Hot panel powered up. These electronic thingys mystify me.
