Oct-12-2017 07:51 AM
Oct-12-2017 04:19 PM
camperguy99 wrote:
The Aqua Hot in my Tuscany 40DX seems marginal to heat the coach. I wouldn't trust it much below 30-35 degrees. Had a lot of problems with it. Yearly maintenance has been done.
Oct-12-2017 04:17 PM
Oct-12-2017 02:36 PM
dougrainer wrote:gutfelt wrote:dougrainer wrote:
The OLD Circ pumps have been discontinued. All you have now are the "New" pumps. The new pumps have a hose and mount nkit to retrofit to all older types. Usual cause of lack of circulation is that check valve. Older systems may need a Circ pump. Doug
actually one can still buy the old pumps but there really expensive like $550 for pump;;
Where? Aqua Hot only sells me the NEW ones, Doug
Oct-12-2017 02:19 PM
Oct-12-2017 02:11 PM
Oct-12-2017 01:33 PM
Oct-12-2017 10:16 AM
sansouci2 wrote:
Thanks! Can you give me the info on the upgrades? Appreciate your help.
Oct-12-2017 10:01 AM
Executive wrote:
The Aqua Hot is a pretty simple unit. BTW, that is NOT antifreeze, it's boiler fluid. Do NOT refill your reservoir with antifreeze. Anyway, the boiler fires and heats the fluid which in turn gives you heat inside your unit. Each one of those fans are separate from each other. Check to ensure each fan unit is functioning properly and getting fluid thru them. If it's an air lock, they should be able to easily bleed the system if they know what they're doing. Be sure, while they have it, that they service the nozzle assembly and also check the fuel pump pressure.
You said they've only had it since Monday. I think two weeks is a dealer minimum to keep your coach regardless of the 'fix'...:)....Dennis
Oct-12-2017 09:49 AM
Oct-12-2017 09:46 AM
Oct-12-2017 09:38 AM
sansouci2 wrote:
I agree with you. It is just really frustrating to us, They have had it since Monday, you would think it would be fixed
Oct-12-2017 09:36 AM
Oct-12-2017 09:33 AM
sansouci2 wrote:
To my knowledge the valve has NOT been replaced!! The fan does run blowing only cold air. They say the pumps are pumping.
Oct-12-2017 09:26 AM
Oct-12-2017 09:18 AM
sansouci2 wrote:
They still have the MH. They actually replaced the leaking pump, not the valve. I am just trying to figure things out too. We really want to head south soon!
