Johno02's avatar
Johno02
Battery charging, Again!!
We have just had an opportunity to boondock for a few days, and it raised a question for me. I use a CPAP machine, running from the coach battery with no problem. However, I did need to charge the batteries some each day after a full nights use. I can charge the batteries either with the generator, or from the alternator on the main gas engine. With the generator, 110v power goes to the converter, which then provides 12(?)v to the batteries. using the main engine, 12v charging is direct from the 12v alternator on the engine. For a quick charge top-up, which is best??
