happy-2's avatar
happy-2
battery cutoff switch
I turned off the battery cutoff switch to the house battery and couch battery but was still able to stare the couch, is that normal ?
  • WELL WELL WELL. Called Fleetwood today and told them about my problem ,they told me THAT even though the battery cut off switches were off when I put in the Ign key to start the coach it is an override.SO I don't have a problem. thanks all
  • Normal? Yes, no, maybe as in by design, production change, modification, etc.
    My engine and tranny computers cannot be turned off. Monaco's house battery switch leaves various item running.
    My self installed battery switches shut everything down.
  • 2006 southwind 37c. with the battery switches off the awning won't retract, but when i try to start the coach it starts and the radio works ,
  • That is normal on my MH. Engine and entry steps will still work.
  • Not normal for mine. When I cut off the main switches for house and chassis, everything is dead until I turn them back on. What kind of coach do you have?
  • SORRY....COACH as in RV. when I turn The Coach battery switch off the light in the Radio goes out but I can still start the RV.
