Diplomat_St_Poo
Sep 27, 2018Explorer
enblethen wrote:
I would look to see if the slide(s) are not adjusted correctly. When they get nearly closed the systems jambs up and breaks the shear pins.
You need to locate the make and model of the slide mechanism.
The slide goes in and out very easily. When the shear pin breaks I can push it without much difficulty. It has no gaps showing on the outside of the MH when it is in.
I did some measurements and both side seem even.
I think the slides were made by RBW Industries but there is nothing on them that says that. Just going by what I have seen on other forums.
Nothing seems obvious except it doesn’t stop when it gets to the end. The other 2 slides work fine. This one did as well till now.
