cm2785
Oct 22, 2017Explorer
Best oil for 460 with 11k
Hi guys my 96 Bounder 34j F53 has the 460. The rig has 11k. What do you guys think the best oil is? I’m hearing Rotella for the zinc but it’s not in 5w30. Any advice is greatly appreciated!
WILDEBILL308 wrote:
I just wonder why people buy an expensive investment and run the cheapest oil they can find not the best oil they can find.
I ran the 0-30 in my 460 when I had it.
Bill
T18skyguy wrote:
I saw a demonstration once of two engine oils tested against each other. The test rig simulated oil passages all the way up to the cam, and was made of glass. One oil was straight 30 weight and the other 10-30. The 10-30 always got to the cam much faster than the 30 weight, but the interesting part is it remained true even in 90 degree temps not just cold temps. The lesson being always use a multi-vis oil.
Old-Biscuit wrote:
Any oil that meets/exceeds mfgs recommendations and change it regularly
azdryheat wrote:
The best oil is the one recommended for your engine and cahnged regularly. There is no magical best oil. I've never found one oil to be better than an other and have never heard of any oil causing an engine failure. What ever weight oil that is recommended for your engine is what I'd use. Dino or Synthetic is your choice. Just change it regularly. I wouldn't run diesel oil in a gas engine but that's just me. There's plenty of oils to choose from and they're all good.
