JCat's avatar
JCat
Dec 02, 2020
Best Toad Brake controller Battery
On my trip last week I drove my Tahoe around for the week once I got to the destination in Sedona.
When I went to depart on Saturday the Tahoe battery did not have enough power to pump up and maintain my brake buddy.
This is the first time this has happened.
I have 2 brake buddies, a primary and a spare and both said no go.
So I figured I need a new battery.
I was thinking I should get more of a deep cycle so it would last during my trips of 6 to 8 hours. Or go back to harbor freight and get the cheap solar panel to charge the battery while going down the road.
Anyone tried a different type of battery for this application ?
Thanks for the feedback.
  • If you drove your toad for a week and the battery went dead, you might want to have the alternator checked.
    Richard
  • This depends on how many time the brake system is deployed every day If in city you my be using it a great deal using up battery more then you think. Get a charging line be safe.
  • Just food for thought...we use a Brake Buddy and tow 5-6 days without starting the Jeep. In the 4 years we have been doing this, we have not had any battery issues. I suspect replacing the Tahoe battery will resolve your issue.
    And yes, a charge line will certainly eliminate future problems.
    Gary
  • If your Towed is in the key OFF position why would the battery discharge ?
  • I'd go ahead and get whatever starting battery your vehicle requires. Then, wire in a 12V charge line from your Motorhome to the Tahoe so this won't be a problem anymore with the new battery.
    That way, you won't be using your vehicle's starting battery like a deep cycle battery, and ultimately shortening its lifespan as a result. Cars really need a starting battery, not a deep cycle. If you use a starting battery like a deep cycle and deplete it low regularly....Welll, you shorten its lifespan and end up in the spot you're in now.
    Find a way to run a charge line to your Tahoe, is my vote.
  • Can I assume there is no 12v charge line connected from the motorhome to the toad. That will keep any battery charged while driving the rv.
