sp8goldExplorerNov 06, 2013Brake ProMy Roadmaster Brake Pro is leaking air. When compressor runs, it can build up air pressure to operate the break. Any clues on where to start?
donhoward49ExplorerNov 07, 2013Your compressor has a valve to shootout any moisture in it. Get the moisture out and open/close the valve a few times. Then do what Wolfe 10 said
Related ContentAlaskan pro/conNuWave ProBlue Ox Sway Pro HitchBrake Pro Will Not Shut OffTag axle pros / cons
