โMay-07-2012 04:12 PM
โJun-03-2017 10:59 AM
bghouse wrote:
So I think all my questions were answered now (or I found in other threads) except for :
3.) Is there room in the CA 23A to add in an inverter and additional batteries / solar?
โJun-03-2017 09:48 AM
Mocoondo wrote:
Not "reconditioned" to your satisfaction? Well why did you buy it then? Were you forced or coerced? The only included warranty is one of limited powertrain...engine, trans, rear axle. An aftermarket service contract is available for purchase.
โJun-03-2017 09:23 AM
flavtfan wrote:
Few pics of my El Monte purchased RV. I dig it, overall very good experience with them and they even hooked me up on some stuff I found after I purchased it that wasn't covered under warranty...for FREE.I'm surprised the Cali El Monte missed it on their pre sale inspection but the Las Vegas store hooked me up.
As with all Ford Triton engines, I suggest looking at the exhaust manifolds before you buy and have them repaired if you see any broken stud bolts or evidence of leaking manifold gaskets (black carbon stains on the heads) or ticking noises when cold then going away when warm. I was just so anxious to get it I overlooked it, knowing full well after dealing with my 08 F150 that those engines have some manifold issues(replaced driver side at 60k and pass side around 85k)and when bolts break it's usually the rear ones.
Other than that the rig has A LOT of new parts on it. Driveline was almost new, trans was replaced and only has about 30K miles on it, and several other new items on the engine such as oil pump, hoses, etc.
The service records were very thorough and it was nice to see that not all the major parts had the miles on them that the odo said....same for the generator.
The black tank was even fairly new...new tires as well. I've done some other minor cosmetic OCD things such as purchase new OEM 12v covers for the dash, assist handle bolt covers for the A-Frame assist handles among other small things.
I still want to change out the hub caps to the wheel simulator style and I need to put some arm rests on the driver and pass seats. Anyway, here she is...hopefully the trailer isn't too much, that is the only thing I am a little concerned about but I see rigs like mine towing 16ft enclosed trailers all the time.
The good thing is, it's a 450 chassis with the 4.56 gears and it doesn't have as large of a rear overhang due to being a 25 footer. The rear end was also already braced up from the hitch to the main frame.
I also cut the old 4 pin connector and located the factory brake controller harness (found above the gas tank) and wired in a 7 pin with brake controller.
The size on the inside of this thing with the slide out is pretty amazing in my opinion too and I specifically like the open look of the floorplan since the fridge is on the opposite side vs being at the foot of the bed. Geez...just found out, this site needs to upgrade the picture loading capability.
http://s126.photobucket.com/user/oldman27/media/17968419_10208073202018383_898045551_o_1.jpg.html?sort=3&o=1
โJun-03-2017 08:50 AM
โJun-03-2017 08:24 AM
โJun-03-2017 07:23 AM
โJun-02-2017 10:46 PM
Photomike wrote:Mocoondo wrote:
When you buy used, everything on the motorhome is used. If you want one with all new components, then you have to buy new. They have a hundred or more 23A's for sale. You could have always picked one with less miles and therefore less wear on the above listed components.
I agree with what you say about the used part BUT CA advertises reconditioned and I can assure you mine was not reconditioned!!!! In fact as I was signing I asked the sales person "Do the dishes come with the RV" and he said no they are taken out when we clean them for sale. WELL they were still in my unit!!! Plus a few other things that should have been looked after were not. He said the same thing, which must be a BS line from the company "If you find anything in the first month just call" well you can call but there ain't no one returning calls. Took me six months to get an extra set of keys that I was told I would have in a month then only one key worked of three.
If that is how CA wants to run it, like you mentioned above, they should clearly say it "These are used, buyer beware!!".
โJun-02-2017 10:38 PM
510dogmom wrote:Mocoondo wrote:510dogmom wrote:
I really don't trust sales people and I wonder if I was ripped off. I have been asking for repairs on specific items since I purchased my CA 23A last month. I had it checked over and found that several maintenance items needed to be done...new brakes, new shocks, steering stabilizer, and other stuff. It totals to around $2000. CA refuses to pay for any of it since it is maintenance. Are they getting away with this? I feel like I've been manipulated and I need a reality check if they are responsible for this or if I am.
From your history, I see that you work for CA, so I take your information with a grain of salt.
I would hope that CA would replace these items during the time they check over the systems prior to selling them. It is bad form to say the rig is ready for sale when so much needs repair. Also, the promise to repair items that are found problematic during the first 30 days is bogus. Does CA really want that negative reputation?
โJun-02-2017 06:13 PM
โJun-02-2017 06:09 PM
bghouse wrote:
One more question - is there anywhere online to find the detailed specs for some of these models that are specifically made for rentals? I'm not finding a lot of details on Cruise America or El Monte sites....
โJun-02-2017 06:04 PM
โJun-02-2017 03:36 PM
โJun-02-2017 01:23 PM
โJun-02-2017 01:09 PM
โJun-02-2017 12:16 PM
