4gnomad's avatar
4gnomad
Charging Strategy, 1994 RoadTrek
Hi all, I've been diving back into how to upgrade my battery system in my class B and was hoping someone here could sanity check me. I have a small 100AH 12V coach battery and I'm upgrading to a pair of L16s (6V, 400AH). My RT has the old MagnaTek charger, which is rated at 32A, but the charging circuit to the batteries is fused at 15A.
The L16s accept up to .25C, so they'll take up to 100A for a few hours before the current drops. I'd like to hit that target to ensure a nice long life for these bad boys and prevent sulfation. Obviously that's not going to happen over a 15A circuit. So here's what I'm thinking:
1. Hook up a Powermax or some other quality 100A charger directly to the battery. I think I can just remove the trickle charger that's in there now (and which I've never used).
2. Pull the fuse on the existing charging circuit so that circuit isn't active when I'm hooked to shore power.
3. When I hook up to shore power hook up both the charger and the regular shore power connection to whatever is available (15/30 is all my rig can handle).
4. From another post I also need to protect the circuit coming off of the alternator so I don't overcharge the AGMs if something goes wonky up front and it starts putting out too much voltage.
My main question is with regard to #3 above - anyone see any problem with me charging the battery and running off of shore power at the same time as long as I've disconnected the original charging circuit?
Last, I eventually want to add a few solar panels so I can "top off" with solar at a lower amperage after running the gennie or hooking up for a few hours to recharge. If I'm reading and understanding the charging profile correctly this is a reasonable thing to do. If I do this do I have to always remember to turn off solar charging when I hook up to shore?
