carringb
Jan 28, 2021Explorer
It’s not likely the MAF is the culprit in this case. A dirty MAF will cause a lean condition all the time, to the point it will cause pining, before it ever causes cold-start symptoms.
Vacuum leak is very likely. I even had the PCV valve pop out of the valve cover once, when I let it go about 100k too long and it plugged.
38,707 PostsLatest Activity: Feb 18, 2025
