Feb-06-2016 11:03 AM
Mar-16-2016 08:12 AM
Mar-15-2016 11:47 PM
Mar-15-2016 08:51 PM
Mar-03-2016 03:29 PM
Feb-16-2016 06:01 PM
Feb-15-2016 10:38 AM
Feb-10-2016 07:54 PM
Feb-10-2016 07:27 AM
booty51 wrote:Replace cap and rotor now
The saga continues, Had wife turn on ignition while I was under RV near gas tank, The fuel pump ran and primed the line on it own. I didn't have to hit tank on the bottom to help it out. The engine has started every time I have tried it today and ran smooth. Yesterday all it did was turn over and not fire. I did take the distributor cap off yesterday and looked at it and put it back on. It looked well used inside and corroded , tip of the rotor looked burned, which I think is normal for the miles on rv (83000) . I am sure that it is original . I think I am the second owner . If I still have problems I will replace the ecm . It looks like Casper has left the rv for now. will keep all posted. Thanks for the advice and help
Feb-09-2016 03:24 PM
Feb-08-2016 06:47 PM
booty51 wrote:
Checked for spark , spark coming off coil wire, then checked spark plug wire, pulled spark plug wire off at distributor spark came out of distributor cap to spark plug wire. So appears to be getting spark. Next, I took off fuel filter under vehicle, turned over engine didn't appear to be pumping fuel out of open line. Fun filter was changed last season didn't appear to be clogged up and I could blow thru it freely, reinstalled filter.When engine start it runs good, you just do not know if it is going to start or not. Today I started it up ,it fired right off and ran. after about a minute I turned engine off tried to restart and all it did was turn over, have tried it several times today it will l not start. By the way Coil is external.
Feb-08-2016 06:34 PM
eHoefler wrote:
A bad ignition module can have spark and have a weak to no signal to send to the ecm to indicate it is cranking, thus not turning on the fuel pump.
Feb-08-2016 02:02 PM
Feb-08-2016 01:29 PM
Feb-08-2016 08:47 AM
