- darsben1Explorerdepends on what state your RESIDENCE IS IN.
- jplante4Explorer II
- Bill_SatelliteExplorer II
pedally wrote:
Just wondering if you need a special drivers license for a class A motor home.
As mentioned above, check with the local DMV. FL you do not. TX you do IF the MH weighs more than 26,000 pounds. Other States have varying requirements.
What is your State of residence. Someone here can likely give you a quick answer. - 352Explorer
((((Some folks confuse my attempts to provide accurate information with actually being concerned what they think about my posts. I don't and you should not either.))))
I really like your signature. Although, some would be confused. - BumpyroadExplorerI thought CA had something special if over 40 ft?
MD has/had a 26,000 lb. cut off.
very few DPs under that.
bumpy - lryrob9301ExplorerIf you reside in Iowa as your profile indicates then you DO NOT need any special license to operate a privately registered class A motorhome of any size or weight.
- down_homeExplorer IIBut apples are in in ga.
- SoCalDesertRid1ExplorerIf you did need a different class license, it would not be a class A license.
Class A license is for trucks towing trailers over 10,000 lbs, when the combination also weighs more than 26,000 lbs, and for trucks towing more than one trailer, with a doubles/triples endorsement.
You can tow a single trailer up to 10,000 lbs with a class B license, which is required when the combination weighs more than 26,000 lbs.
Also, since you're in an RV, the license would not be commercial, unless your RV is used for commercial purposes.
This is under US DOT licensing requirements, which all states also follow. - Kayteg1Explorer II.. than RV trailers above 10,000 lb are exempt.
RV are exempt from lot of common laws, so if in doubt- call your local DMV - RoadpilotExplorer
I searched for any info on the above. I can only find DOT requirements for commercial drivers. Could you please provide a link for non commercial DOT requirements as you have stated?
About Motorhome Group
38,705 PostsLatest Activity: Jan 20, 2025
