tatest
May 29, 2016Explorer II
B+ usually has cabinets because thats's all the space there is up there. Most I've seen would be hard pressed to fit a sort, cot-width sleeping area in that space. If you want bunks up there, look for a C with bunk-size section over the cab.
If all you want is storage, you can get as much space as the OEM cabinets used, which for some models is a lot, others not so much.
38,706 PostsLatest Activity: Feb 02, 2025
