squirtdog
Jul 24, 2014Explorer
Class C towing
Looking around for a Class C that will tow 6000lbs(jeep and trailer) Any suggestions? Model? Trying to keep the length to about 25-26 ft. Thanks-Don
Mich F wrote:Southpaw+Bulldog2 wrote:
Need your help...considering switching from a 5th wheel to a Class C; either a Sunseeker 3170DS or Thor 31E.
My question is will I be able to tow my '07Toyota Camry? Both C's have a towing capability of 5k, car is about 4k + from what I've read I'll need to use a tow dolly. Am I correct?
Thank :o)
I don't think anyone can tell you if you're correct or not, with the information you've given. The best source of info is your owner's manual.
You can also go to the Remco site and put in all the requested info and see what they say.
Thank :o)
Desert Captain wrote:
...with a 24' Class you C you have no need/reason to pull a toad.
A 24' Class C doesn't have any frame extensions...
Mich F wrote:
I never had a reason or need to pull a toad with my 24' Class C, but it does have a frame extension.
Desert Captain wrote:pnichols wrote:ed6713 wrote:
I don't think there is an E-450 chassis out there that can safely drag more than 5,000# around.
It's probably not the E450 chassis per se with it's 4:56 rear differential, large diameter driveshaft, and 5-speed (6 speeds internal) transmission ... as delivered by Ford that presents the problems.
The problems are more likely the sturdiness and length of the frame extensions that Class C motorhome manufacturers weld onto the Ford OEM frame ... plus the issue that many Class C motorhome owners have with a truck engine that is designed for, and requires, high RPM travel up grades in order to tap the necessary (V10's) horsepower. ;)
Ah the ever present irony... A 24' Class C doesn't have any frame extensions, rarely causes the engine to "scream", 4,000 rpm is no problem and certainly no screaming/roaring but.... with a 24' Class you C you have no need/reason to pull a toad. :S
:B
