dennysbabe
Dec 14, 2013Explorer
Code 14 on LPG ONAN 5500 - stops on disconnecting load
We have a propane ONAN Marquis Gold 5500 generator in our 5th wheel purchased new in 2008. It has 775 hrs on it and my husband has kept it serviced. No past problems with it except for a previous Fault Code 14 that was fixed by adding oil.
Recently it's been in the shop for other reasons for about 2 months and after bringing it home my husband started it up to let it run for maintenance purposes and it shut off by itself after about 30 minutes and showed Fault Code 14. Both propane tanks are full. He added very little oil thinking it might be that and it restarted without any problem. However, it shut off again after about 30 minutes with the same fault code. Each time it was run without a load. Today he ran it with a load (fireplace and tv) and it ran fine without shutting down for an hour. However, once he turned off the fireplace then the tv, the generator shut off by itself again. This time it gave no fault code (no blinking lights at all). It always starts right up and runs very smooth without any surging. He restarted and tried it again. This time he ran it 45 minutes without any problem then turned off the tv then the fireplace and it shut down again and once again without a fault code.
We are perplexed as to what might be wrong Any ideas or suggestions other than taking it to the shop?
Thanks,
Phyllis
Thanks,
Phyllis
