coljhoss
Apr 29, 2014Explorer
converter bad
1995 bounder class a.the only thing that works is 12 volt lights.plugged into shore power.the converter is behind fuse box.i believe it is bad. can i bypass converter by running hot wire that goes into back of converter strait to main fuse.i believe generator battery and 120 go into converter and 1 wire comes out front of converter to main fuse 30 amp.i realize i wont be able to use generater, but will this work untill i can get new converter.thanks jess
