kmb1966's avatar
kmb1966
Cruise Control - Not working Ford F53
We have a 2001 Itasca Suncruiser F53 V10 Chassis. The cruise control used to work, then sometimes would work, now can't get it work at all.
There is no dealer in my area, so I'm having to bring it to mechanic shops where they always say the same thing: "Yes we can fix it", but in the end.... they don't fix it. All I end up with is a invoice for a non-working cruise control.
1. The Ford recall has been completed. No leaks on the brake pressure switch where the recall wiring harness is installed.
2. Cruise control fuses are good.
3. Recall wiring harness fuses are good.
4. Both shops say brake pressure switch is good.
5. Brake pressure switch has not been changed though.
6. There is no 'light' on the dash board for the cruise control, so difficult to tell if it is even coming ON. I can't even figure out WHERE the cruise control module/servo is located. Anybody know?
