lBumster1's avatar
lBumster1
Cummins engine dies and then !!!
2002 National- Islander, 40 ft. - Cummins Diesel.
on trip to Bremen,In.in Sept.2013 our coach quit running and after pulling off to side of road we determined engine was idling but when pressing gas peddle unable to increase RPM's and then coach died. Coach immediately restarted and we continued for about an hour and then same thing happened EXCEPT, after engine died and I turned key to restart there was no electrical in the dash. After a few tries it come back to life and restarted. Had this problem in the past and replaced ignition which didn't help and then cleaned up all ground wires that I could find and that seemed to solve the problem at least for a while. One occasion in which this happened it appears the cause was battery cables vibrated loose and after tightening problem seemed solved. August 2013 happened again and was able to get to the Cummins Dealer and computer readout said fuel transfer pump was going bad. Pump replaced and it was about 600 miles before issue popped up again. Looking for IDEAS/THOUGHTS
