Jun-08-2013 06:42 AM
Sep-05-2013 07:58 PM
Jun-10-2013 07:05 PM
dougrainer wrote:Mr.Mark wrote:
I might be mistaken but A/C is A/C whether it's in a class A diesel or gas unit, right? We can run the dash A/C up to about 95 degrees outside. After a prolong period of that temp, the rear starts to warm up from the engine heat.
Anything over that temp I'll crank up the genny and run all three air conditioners. It's nice to arrive at our destination with the interior cooled off on a hot day.
MM.
Yes, you are mistaken. Rear Engine Diesel will get colder than a Gas engine front. The reason is the gas engine heat of the forward compartment and the fact that the Condenser FOR the AC is installed in front of the Gas Engine Radiator and Gas engines run hotter than Diesels. Also, the Condenser for most Diesel's are separate from the radiator and even if part of the radiator, the Diesel runs cooler and the ability for a Condenser to remove the heat from the AC coolant and the better it does that is a big factor in how cold a Dash AC will get. Doug
Jun-10-2013 05:19 PM
Jun-10-2013 05:40 AM
Jun-09-2013 08:01 PM
2005 GulfStream Ultra Supreme, 1 Old grouch, 1 wonderful wife, and two silly poodles.
Jun-09-2013 07:46 PM
dougrainer wrote:Groover wrote:
Automotive air conditioners use a cool-reheat system where the air is cooled by the air conditioner and then warmed to a comfortable temp if full cooling is not required. It can even be heated to an elevated temp for de-fogging the windshield. If the reheat function is not shutting off properly it can make your airconditioner useless. Turn your system to "Vent" and the temp all the way down and see if the output air is warmer than the air coming in. If so, you have a heater control problem. Some Fords have a valve in the hot water line supplying the heater that is supposed to shut when no heat is asked for. If that valve leaks your air will be warmed somewhat, how much depends on the leak rate. My father had a Ranger with that problem new. The dealer's mechanics had no clue how the system worked or what that valve did. He finally replaced the valve himself and solved the same symptons that you are describing.
Good Luck.
ALL CORRECT. BUT, NOT for RV motorhome systems. Motorhome systems have no such blend door system like Automotive systems. Yes, if the Hot water shut off is seeping or not closing, the AC will not cool but when that happens on a motorhome system, the air output will be over 100 degrees and higher. Doug
Jun-09-2013 10:57 AM
Jun-09-2013 10:29 AM
Jun-09-2013 07:12 AM
Jun-09-2013 06:26 AM
Jun-09-2013 06:08 AM
Jun-09-2013 05:45 AM
Good Luck.
Jun-08-2013 08:56 PM
Jun-08-2013 11:34 AM
MM.
Jun-08-2013 10:34 AM
