bounder39zman
Aug 09, 2014Explorer II
Dead Cummins ISB/275
Looking for some help with Cummins ISB/275hp in DP motor home.
Started normally, backed it out of garage, went to close garage door and engine stopped, just like key switched off. Will nor re-start. Cranks at normal speed, but not seeing any sign of smoke out of tailpipe. Changed fuel filter, checked electric lift (supply) pump, it is running and have fuel delivery when cranking. Any ideas? Also, anyone know how to release spring (parking) brake, as I have no air pressure due to no engine running..so I can pull vehicle back into shop?
RV is on a Freightliner chassis, with an electric throttle mechanism. Any suggestions would be appreciated...I can swap for Generator info, as I work on Onan/Kohler/Generac, etc at my work
