- 2oldmanExplorer III use Heng's rubber roof coating for light repairs. More like paint.
- FreightguyExplorerTheir both good, but I like dicor a little better.
- magik235ExplorerBoth depending on the configuration needed.
- FIRE_UPExplorer
SGTJOE wrote:
Should I use Dicor self leveling chalk or Eternabond tape on my MH roof?
Well,
It's kind of a matter of opinion. I see so many run out and buy the tape when a self leveling caulk product works just fine. The real trick in obtaining the best results is, you have to put EFFORT into cleaning the areas in question, in order for the Dicor or, any other self leveling caulk to do its job.
I've re-sealed many-a joints, vents, roof-top fan vents, shower skylights, cap ends and more, with Dicor. It's always worked absolutely flawlessly due to the manor in which I prepped the area before application. It's actually quite simple. I use a heat gun to really soften any and all old caulking. And that includes working on a rubber roof too.
Then, while the old caulk is really supple and plyible, I scrape it all off with a nice, 1 1/2" stiff bladed putty knife. Once the area is devoid of all the old caulking, I wipe the area down with alcohol thoroughly to make sure there is no oils, or handprints etc. Then, out comes the new Dicor tube. If a tube appears to be aged, it's trash. The product is too cheap to save it for months or years and then break it out of hibernation and squeeze every last drop. Get a new tube.
I mean, $10.00 or so for a new tube?? That's cheap when compared to ANY roof leaks. I just did a few roof top items on our '04 Itasca Horizon 36GD and, it came out flawless. Your choice.
Scott - JimExplorerEternabond tape. Hardly any prep needed other then washing the roof. Cut it, press it in place, roller it, done. And never need to do it again.
- dave17352ExplorerI use both and both are fantastic products. I think each has its place. I think if I had to give up one or the other I would part with eternabond first. If you were to look at my roofs they would look just like the earlier posters Majik235's.
- ScottGNomadEternabond tape if you can use it. Some places you just cant.
- Dicor works fine with me. EB seems a bit permanent. Applied correctly they both seem to work well.
- MrWizardModeratorWhere is it going, what is it sealing ?
This determines what is best
For square roof vents, I prefer Eternabond tape
For round plumbing vents, use some clay or something to make a little coffer dam, around the vent then poor in the Dicor
Self leveling will flatten out and run down hill, so you must be level and have a way to maintain thickness
I'm not real fond of the self leveling caulk, unless I'm trying to fill a crack in a roof seam
I really prefer regular thick caulking that stays where I put it - SGTJOEExplorer IIAnyone have pictures of their roof seams sealed with eternabond tape? If I do the tape should I try to do it in one length or in pieces?
About Motorhome Group
38,705 PostsLatest Activity: Jan 14, 2025
