Wilbur
Sep 11, 2016Explorer
Diesel ?
Sold my class A gasoline Motorhome a couple years ago because we weren't using it enough to justify ownership, storage, etc. Now we are thinking about getting another. Think we would like a diesel b...
willald wrote:Ivylog wrote:
Farm equipment sits all winter... my DP just sat for five months without being started... much shorter than some of my heavy equipment. Starting every month is about as dumb as changing the oil every year reguardless of the number of miles on a diesel that does not travel short distances. I've run diesel fuel that was five years old in my equipment... you cannot do that will five year old gasoline.
This is an expensive sport, no reason to make it more expensive.
A Motorhome needs to be driven a few miles at least once a month or so, to exercise the rest of the chassis, not just the engine. Regardless whether its gas or diesel (although it probably is true that this is more crucial for a gasser, due to the risk of bad gasoline fouling up an engine.)
If you let a Motorhome sit for 5 or 6 months at a time every winter like you're suggesting here, eventually you're going to have all kinds of fun with the brakes. Sticking calipers, etc. Not to mention that when they sit that long, you run a higher risk of critters getting into it and wreaking all kinds of havoc.
I remember when I first bought our Motorhome, that was the first thing we were told by our mobile RV service guy we've known for years and who has worked on these things for years and years: The WORST thing you can do to an RV, especially a motorized one, is to let it sit. These things need to be driven, used.
I agree, its an expensive sport, no reason to make it more expensive by not exercising the chassis, and causing expensive issues later on. Even if its just a drive around the block a few times, fire the thing up and drive it 'bout once a month. If nothing else, it helps keep you excited about getting back out camping come Spring. :)
