Differential Oil Capacity
TC_Z
Preparing to change the differential 75W-90 oil in my 2007 Winn. I am finding conflicting amounts, 3 pints, 3 quarts, many gallons!!
What is the correct capacity so I buy the correct amount?
Thanks....
Year: 2007
Make: Winn
Model: Voyage 38J
Serial: 10F90H253787
VIN: 5B4MPA7G573422088
TC&Z
2007 Winn Voyage 38J, gas 8.1L engine
2018 Jeep Cherokee flat tow
3 REPLIES 3
oldave
Most are using synthetic nowadays.
fyrflie
http://www.oemys-performance.com/library/gear%20lube%2004.jpg
This might help others in the future.
TC_Z
Found out I should get 2 gallons.
Thanks
TC&Z
