walter_abela's avatar
walter_abela
dometic ccc wall thermostat
my dometic CCC 2 wall thermostat developed a code 3 last night and
my system shut down. woke up this morning and system is
working perfect... what caused it and does it sound like
my thermostat is taking a dump? on vacation with cat on
board and wife is really worried... thanks for your input
  • thanks for all your input... i totally agree the thermostat
    must be taking a dump..... will replace ...
  • Halmfamily wrote:
    Turn your t-stat off, both zones. Press and hold the zone and mode buttons at the same time. This will reset your t-stat. I've had to do this the last 2 trips out and will have my dealer replace it tomorrow.
    You also should have thermostat turned off, hold zone and mode buttons while turning thermostat on, this will reset.
    Terry.
  • Turn your t-stat off, both zones. Press and hold the zone and mode buttons at the same time. This will reset your t-stat. I've had to do this the last 2 trips out and will have my dealer replace it tomorrow.
  • E3, Is a shorted INDOOR temp sensor. So, either the wall tstat(CCC2) is the indoor temp sensor or the system has a remote temp sensor on a wall or ceiling. It depends on how many roof AC units you have and where the CCC2 is located. Usually Zone 1 AC the CCC2 will be the indoor temp sensor and the Zone 2 will have the remote interior temp sensor for that Zone. But, if the CCC2 cannot be mounted where it can sense the Zone 1 indoor temp they will install a remote temp sensor for Zone 1. Yes, if the CCC2 is the temp sensor, then it has a fault and needs replaced. Resets do NOT fix operational/error problems on Dometic CCC systems. Doug
