Ro646a's avatar
Ro646a
Dometic Penguin 2 stops running after a few minutes
My motorhome has 2 rooftop A/C units. The rear unit it a Dometic Penguin 2 A/C unit that was replaced about a year ago, before I bought the motor home. If I run it on shore power the fan cuts off after about 10 or 15 minutes and the compressor keeps running. If I run the fan only it will run all day. I have 114 volts and 228 volts at the motor home on shore power at my home.
If I run the generator it will run all day without any problem. The front unit is the original Penguin unit and it runs just fine all the time.
Has anyone experienced anything like this? Any thoughts as to what the problem might be?
Thanks in advance.
Roland
