drivers door panel removal 2001 E450,
Raymond_Quintal
The mirrow on the drivers door is about to fall off my 2001 E450 c class motor home. It is a power mirror with a heating eliment. it appears I have to take the door panel off to get to the mirrow attachment bolts. I removed the only two screws I could find, one AT UPPER corner by mirrow controls and one at lower left corner of door panel. I tried to remove door panel by pulling out to release any clips with no results. it appears that there are more screws or some type of attachement in center of door which I can not find. anyone know how to remove the door panel or thighten the mirrow. Thanks
5 REPLIES 5
ronfisherman
Moderator
Moderator
Closed.
Please refer to this thread.
mirrow loose
2004 Gulf Stream Endura 6340 D/A SOLD
2012 Chevy Captiva Toad SOLD
phillyg
Try searching on youtube for a demo video. I found one for my F150 when I had to replace the window motor.
--2005 Ford F350 Lariat Crewcab 6.0, 4x4, 3.73 rear
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
1492
Moderator
Moderator
Moved from Forum Technical Support
trnfla
Look under the door handle or inside the handle. The part you pull on to close the door.
Now 2004 Winnie Minnie 31C
Had 2007 Zeppelin 190 Hybrid,
1999 30' Dutchman Classic FW
Dr_Quick
I would recommend that you get a "Haynes Repair Manual" for a Ford Super Duty of the year range that you have. There will be a section in manual on door panel removal.
Dr Quick
