โApr-15-2017 06:14 AM
โApr-20-2017 02:13 PM
VA-Apraisr wrote:
I'm not sure if Tow/Haul is a button to push, or just taking it out of overdrive when climbing/descending a step hill. 2003 Ford V-10 and all I have is the overdrive button on the shifter. Maybe newer units have this button?
โApr-20-2017 12:59 PM
โApr-20-2017 11:46 AM
โApr-19-2017 08:36 PM
Jackha1949 wrote:
You may want to add gas stablizer to your fuel tank before storing your rig for any length of time. It will prevent your gas from degrading and gumming up your engine especially your generator carb. I don't hear much about using gas stablizer in RVs, however, it is used regularly in storing boats. Hope this helps.
โApr-19-2017 07:37 PM
cross21114 wrote:Desert Captain wrote:
"I did not use tow/haul mode except in some severe situations."
That's too bad as the non use of Tow Haul is hard on the trans {it runs hotter}, and hard on the brakes as they are needed far more than with the proper TH use. Every Class C renter {at least a dozen}, I have spoken with was never told about using Tow Haul. Just another reason I will never buy a former rental unit.
As always.... Opinions and YMMV
:C
Please explain how running in tow haul increases the trans temp. It would seem to me that the opposite is true. Certainly the engine runs at higher rpms and burns more gas. If you drive easy, you don't need to ride the brakes. I experience much better performance running my Expedition without tow/haul.
Thanks
โApr-19-2017 06:44 PM
:C
โApr-19-2017 11:47 AM
โApr-19-2017 11:09 AM
โApr-18-2017 06:18 PM
โApr-17-2017 07:12 AM
โApr-16-2017 01:11 PM
โApr-16-2017 12:06 PM
โApr-16-2017 09:19 AM
โApr-16-2017 08:40 AM
theoldwizard1 wrote:Desert Captain wrote:
Nice to see that the myth of using higher octane to solve mechanical problems is still alive. :S
30+ years of automotive engineering disagrees with you.
I qualified my response by saying "ping" from pre-ignition can be cured by higher octane. Why the pre-ignition is occurring is hard to diagnose, but likely it is from carbon build up inside the combustion chamber.
Higher octane fuel will not ignite until a higher in cylinder temperature is reached, such as an actual spark event nor just a "hot spot".
In my case, anecdotal evidence proves I am correct.
