mjdimino's avatar
mjdimino
Electric patio awning wont retract
I cant get the electric patio awning to retract. I can hear the motor running (it is apparently in the roller) but the awning will not roll up. What can I do to roll up the awning at least on a temporary basis so that we can travel. It is made by Care Free.
  • why don't you people READ THE DAMN POST and stop asking questions about waht has been stated!!!!!!!!!
    as for your question:
    This is from Carefree
    Good afternoon and thank you for your email. With the owner's manual
    you received a set of jumper cables. Disconnect power to the awning and
    attach the jumper cables to the rivets on the plastic housing of the
    motor. Attach the other end of the jumper cables to an alternate 12V
    source.
    If the motor is still not working after trying the jump start, the
    awning will need to be manually rolled in. Remove the 2 screws that are
    holding the motorized arm to the roller tube. *****Please note: If the
    awning is partially closed someone will need to hold the arm channel as
    the pressure from the gas shock will open the arm all the way. Once
    detached, you can walk the arm to the full extension and allow it to
    hang in place. Also, be sure to support the roller tube once it is
    disconnected. ** Carefully detach the roller tube from the motorized
    arm.
    Manually roll up the fabric and tube, while someone is pushing the
    non-motorized arm towards the coach. Once against the coach, re-secure
    the motorized arm assembly to the roller tube. It may be necessary to
    secure the arms for travel.
  • when it happen to me Zip ties work the best, Duck tape residue is a pain to get off
  • If it's a Girard, there is a wand that you insert into a slot and crank it in....Dennis
  • You'll probably have to get a ladder and roll it back manually. Have someone hold the power switch in the retract position while doing so, just in case it catches. Make sure you bungee or duct tap both ends to keep it in place.
