I have a winnebago aspect, 2014, 30-j unit. I have a electrical problem, the lights {2} above dinette will not shut off with the switch. The only way to shut them off is to shut down all power to the coach. I replaced the switch and again i have the same problem. I would appreciate any suggestions on this matter. thanks, tom
Do they have the button on the bottom of them? Some of mine do and some don’t. May be a bad switch or shorted wiring. Find which wire is the hot wire and make sure it is on the correct terminal. Will the lights work with the switch removed?
These lights have worked fine since i bought the unit 5 years ago, until last week, however i did switch the wires,after i replaced the original switch but no change.
