yves1956
Dec 14, 2013Explorer
Electrical problem
I have an Holiday Rambler Admiral SE 2003,one of the air conditionner (Dometic Duo-Therm)on the roof top was leaking water Inside. What is the problem?
Thanks
yves1956
Thanks
yves1956
yves1956 wrote:
Thank you for answering my question.
Finally I shutted down all the power and remove everything that was plugged to the circuit (outlets). I removed the GFCI and rewired the whole thing, now it is working properly. Removing all things that were plugged, I found out an extension sitting on the water outside.
That was probably the problem. Thanks to all for your help.
