Geocritter
Apr 12, 2015Explorer
RLS7201 wrote:
The correct cylinder head part number for your year MH is F3TE. The number is to be found between the two center exhaust ports on the head.
E7TE heads will work but are for 1988-1993 EFI 460s.
F3TE heads have bigger valves and redesigned ports.
NO other part numbers will work correctly with your EFI manifolds.
Richard
I didn't find the cylinder head numbers and suspect I have the earlier cylinder heads used on carbureted engines. The previous person who worked on it used non-standard (for the 1994 engine) intake manifold gaskets (probably for the 93 and earlier FI heads). I had a heck of a time finding the gaskets that were used and ended up finding them on eBay. You are correct though, it's not right and to make it work the bottom of the gasket acts as an extension of the intake manifold (the gasket has a thin metal layer sandwiched in the middle. It'll be nice having an engine for a change with all the correct parts!
Steve
38,705 PostsLatest Activity: Jan 20, 2025
