Jones1
Aug 30, 2019Explorer
Evans?Tempcon a/c & air dump valve '99 DS, Frt Liner
Little help if possible. I have a '99Dutch Star,Frt Liner,Cat3126.
I have a problem with the Evans Tempcon unit in that the vacuum pump clcles on and off.It does operate the units doors. It started the pump would run continuously. Carried it to RV service center and he replaced the vac. lines from pump to vac. tank and from tank to the selector switch on the dash. Pump quit running cont. but cycles on and off. I pulled the line from pump,plugged ,pump shut off,pulled the small line from the resv,plugged theoutlet on the tank,pump shut off,pinched the line from the res.at the dash selector switch and the pump cycles on/off. All lines are new to this point.
Also having a problem with the dump valves for the air bags. Found the fuse in the HWH control unit(HWH 310) system. Replaced the fuse and as soon as I try to dump the bags blows fuse. It lookslike the system has 3 dump valves. What would be the procedure to check these valves, if I can located them? I assume Newmar installed the levelin system not Frt Liner.
Any advice help would be most appreciated.
Thanks for reading
Roy Jones
Thanks for reading
Roy Jones
