two_travelers
Feb 16, 2017Explorer
Figuring the correct tire pressure
Recently had our coach weighed. We are at 6,700 lbs (3350 per tire) front and 12,180 lbs (3350 per tire) rear when fully loaded. Tires are Goodyear G670. Using the tire pressure chart from Goodyear it would appear that 80 lbs psi is what we want. At that inflation, the steer axle weight is 3640 lbs and rear at 3415 lbs. Tire inflation chart on coach shows 92 lbs psi. It rides like its on hard rubber tires. Should I use the 80psi or bump it up a few lbs? Thanks to all who share their knowledge!!
