Apr-26-2015 10:40 PM
Apr-28-2015 10:02 AM
Apr-28-2015 08:36 AM
Apr-27-2015 06:09 PM
Apr-27-2015 04:29 PM
FIRE UP wrote:
Tinstar,
Yeah, a TPMS most likely would have notified you that you had a problem. But, I'm wondering something here. You state you were rolling just fine, silk as could be, right up to the point you stopped at the light. But, the INSTANT you started to take off from the light, you KNEW you had a flat tire, correct?
Now, unless you had your music up to TEEN-AGER-LEVEL and your wife was disco-dancing on the dash, don't you think that you should have heard the 100 psi. instantaneous blow out, while sitting at the stop light, based on the fact that you said the ride was flawless up to that particular spot??? I'm certainly not chastising you here. Not at all.
Did you have any pulling of the front end, especially during braking, or any other even remote ill handling effects prior to the stop? If not, then the air escape had to be pretty near blowout speed AND NOISE VOLUME, in my opinion, at that stop light. This is all just surmising things here.
And, since we're on the subject of changing your own spare on a diesel pusher. About 99.99% of the lug nuts on those Diesels are on with usually around 450 ft. lbs. of torque, correct? May I ask, your procedure for breaking them loose and all that? This is really interesting to me. I carry a "Torque Multiplier" on board that allows me to break all 10, 450 ft. lb. lug nuts, with one arm, while sitting.
But, that really doesn't do me any good since I don't carry the spare. I would only use it if, we had a blow-out and, was anticipating Road Service sometime soon. That way I'd just speed up the tire changing process.
Scott
Apr-27-2015 02:32 PM
rgatijnet1 wrote:mike brez wrote:
I used my coach air and pumped it up and could hear a small leak at the stem. I noticed a Michelin tire sign a mile or so away when we pulled in. Drove over to the shop,a hour later and $47.00 all was good.
Funny the short time I was there at the Michelin store I saw two sets of 22.5 Hankooks being installed.
You should have bought the foreign tires because they never leak at the valve stems. :B
Apr-27-2015 02:24 PM
tropical36 wrote:Funny the short time I was there at the Michelin store I saw two sets of 22.5 Hankooks being installed.
That's cuz a genuine Korean and Chinese made Hankook is as good as any Michelin, with the only real difference being in the price.
Yep, even the Koreans are subbing out to China, as every other company on the planet will and if they haven't already.
Apr-27-2015 01:37 PM
bluwtr49 wrote:
Spare???? No way on earth could I change one of my tires plus trying to find bay storage for a tire and wheel of this size and that does even account for buying and storing a jack....just not practical. I'll bet the tire and wheel must push 200 lbs. Just to make matter worse the rims are different between front and rear...not sure of the tag.
Apr-27-2015 01:36 PM
Apr-27-2015 01:31 PM
Apr-27-2015 11:56 AM
Apr-27-2015 11:31 AM
Apr-27-2015 11:04 AM
mike brez wrote:newman fulltimer wrote:
Willing to bet a bad valve, stem
I woke up to one of those two days ago while on the road. While I was waiting for my wife to get ready for our morning excursion, I went outside and was sipping my coffee doing a walk around the rv when I noticed my rear outside tire looked low. I whipped out my tire gauge and it was fine. Checked the inside and read zero. I used my coach air and pumped it up and could hear a small leak at the stem. I noticed a Michelin tire sign a mile or so away when we pulled in. Drove over to the shop,a hour later and $47.00 all was good.
Apr-27-2015 11:00 AM
gbopp wrote:
Thanks for sharing.
This is why I think carrying a spare is a good idea. JMO
Apr-27-2015 10:54 AM
Tinstar wrote:
A TPMS could have helped but I doubt it. I'm reasonably sure it was fully inflated when I pulled up to the light. I had to slowly roll forward as I approached the light and it was as smooth as silk. When I pulled away at the green, the tire had not made one rotation before I knew for sure it was flat. I would bet there was something in the roadway at the light and I got it, loosing air while I waited for the green.
There won't be any warranty reimbursement I'm sure. Driving on it for 150 yards to get out of one of the busiest intersections in Denton didn't do it any good. I'll see when I replace it if the tire guy can determine what it was.
